Hard to shift 1st and 2nd.
Old May 12, 2008 | 06:38 PM
CIA's Avatar
CIA
Default Hard to shift 1st and 2nd.
I have this little problem. I dont worry about too much but i will ask anyway.
Symptoms:
- Hard shifing 1st and 2nd only (occasional)
- Its random.I could shift with 1 fingerfor 3 stopsina row and then out of nowherei need to force the shift **** to get into 1st and second.
- Ithappends more oftenwhen the car is on a hill/downhill.
I suspect somemount isworn out. Tran/engine mounts.
Someone has an idea?
Old May 12, 2008 | 07:01 PM
cincyTT's Avatar
I'm make believe
Default RE: Hard to shift 1st and 2nd.
change the fluid to Redline MT90 and you will be good
Old May 12, 2008 | 07:17 PM
CIA's Avatar
CIA
i was planning to do the flush this week. But i cant imagine that only the trans fluid can affect the transmission so badly.
Old May 12, 2008 | 07:57 PM
cincyTT's Avatar
I'm make believe
Well when its not lubed well enough the syncros suck
Old May 12, 2008 | 07:58 PM
pyropenguin's Avatar
I used to have that, I recently changed my clutch/tranny mounts and it went away. I'm betting new tranny mounts will fix that right up for you.
Old May 12, 2008 | 08:04 PM
fumoazul99's Avatar
how do you change the tranny fluid on a b5 1.8t? theres a 2.8 DIY out there but i dont think ive seen one for the 1.8t
Old May 27, 2008 | 10:53 PM
e8myshrts's Avatar
If your grinding it's likely too late. If it's just tough then a fluid change will be in order. I've found that Royal purple gear lube provides a bit better shift feel than redline mtl. Make sure whatever lubricant you use is GL4 spec, GL5 is too slippery.
Old May 27, 2008 | 11:28 PM
A4Cragman's Avatar
On the topic of transmissions, mine has a small issue with 3rd. I dont have a problem shifting any of the gears, they're all super smooth to make the shift, but 3rd shimmies a little. It's not like a full shaking of the car type shimmy, just if I happen to have my hand on the shifter **** while its in 3rd, it vibrates, and it vibrates harder if I push it forward just a little, which isnt something I do on a regular basis, it just happens to be that when I first felt it vibrating when I softly rested my hand on the **** while cruising in that gear, I thought it might not have been in all the way so I nudged it forward and it made it worse. Could this be a fluid problem or is it more likely to be the brushings or something just in the shifter and not the tansmission itself?
Old May 31, 2008 | 12:07 AM
rlubbers's Avatar
i have noticed the same thing on my car, but i just stopped resting my hand on the shifter
Old May 31, 2008 | 12:58 AM
A4Cragman's Avatar
ORIGINAL: A4Cragman
tansmission
hah. outrageous mis-spelling dab.
