Having Issues with Idle For the First 30-40 seconds? (Then issue goes away) Help Any1
Old Nov 27, 2010 | 03:31 PM
ben9919591's Avatar
Exclamation Having Issues with Idle For the First 30-40 seconds? (Then issue goes away) Help Any1
2000 A4 1.8T, 127k Manual.
I got the car slightly hit and got it fixed. Car came with aftermarket intake
Everything ran fine, but when i switched back to a stock intake it started idling rough and the car turns off unless i give it gas and keep the idle 2000rpm's or higher for 30 to 40 seconds. After that it runs fine on its own.
This only happens when its cold, If the engine is warm, starts with no problems.
Old Nov 27, 2010 | 03:40 PM
dragonrage's Avatar
Unplug the battery for a while to have the car re-learn how to run. Also, clean your MAF.
Old Nov 28, 2010 | 12:14 AM
Mike-2ptzero's Avatar
Could be an issue with the SAI pump.
chocalotstarfish
Jul 7, 2010 09:16 PM
kc
Sep 30, 2008 12:03 PM
whitejeepXJ
Apr 2, 2008 02:03 PM
acvega
Mar 8, 2005 02:06 PM
