Headlight washers
Old Feb 17, 2008 | 02:05 PM
DJTR's Avatar
Default Headlight washers
Ok so while installing my HID's I started checking over the headlight washer system. Everything I can see looks good, I even pulled the headlight washers up and the nozzels are in good shape the lines look good, but I can't find the pump or why the damn things aren't working lol. The fuses should be good as the windsheild washers work mint.
Any ideas? and where is the damn pump so I can check the wires and replace if necessary. No one seems to have a repair manual in stock in this city :S
Old Feb 17, 2008 | 07:09 PM
DJTR's Avatar
Default RE: Headlight washers
Bumpy Bump?
Old Feb 17, 2008 | 09:45 PM
30vQuattro's Avatar
i'm trying to find out that same thing... i don't know how to turn them on... the manual doesn't tell you ****!... lol
Old Feb 17, 2008 | 09:49 PM
manufan's Avatar
They only work if the headlights are on....
Old Feb 17, 2008 | 09:52 PM
pimphell's Avatar
I think you have to have the headlights on and then hold the winshield washer lever on for longer that5 sec.....
Old Feb 17, 2008 | 09:56 PM
30vQuattro's Avatar
i'm gonna try that!!! i think the last time i did it i held it for like ten seconds and they still didn't come on, i had the lights on, the foggs on, the rear fog on!!! everything!hahaha.. thanks
Old Feb 17, 2008 | 11:29 PM
david9999's Avatar
Lights have to be on for them to work.
Old Feb 18, 2008 | 11:07 AM
ejgold55's Avatar
having the same problem on my 98.5 [:@] PLEASE let me know if you figure this out
Old Feb 18, 2008 | 01:33 PM
30vQuattro's Avatar
yeah please post something once you figure out what it is... they stilll come up or spray. thanks
Old Feb 18, 2008 | 01:38 PM
hiwords's Avatar
they also work if you hold the washer lever and flash the highbeam a couple times
