Heater blower won't shut off
Old Jan 10, 2013 | 03:28 PM
ECS Tuning's Avatar
Sponsor
Originally Posted by mtroxel
I believe "relay" is a module that's built onto the blower motor. It's not just a resistor like the old systems, but some people still call it that. Check this out, scroll half way down:
OEM / Performance Parts for Audi, BMW, Mercedes Benz, Mini, Porsche & Volkswagen - ECS Tuning
But don't go buying a part based on this post. I'm still not sure what's going on. That "fresh air blower voltage static" code is a big clue, I'm just not sure how to nail it down without doing a buch of searching that you can do.
Thanks for posting the link!
OP - most of the time when this happens its because the climate control buttons get stuck. This happened every once in a while with my B5. I used some circuit board cleaner that I got from radio shack and a couple q-tips. Since I did this the problem never returned.
Good luck!
Jason
Old Jan 10, 2013 | 03:33 PM
ch19251's Avatar
Thanks Jason,
How did you go about cleaning the buttons? Did you pull the env unit out and disassemble or just spray it on there and work the buttons?
Old Jan 23, 2013 | 08:21 AM
ch19251's Avatar
Hi, just wanted to let everyone know my heater blower woes were solved by replacing the blower motor resistor. Based on the codes from the env controller and that I had total control over where the air came out and temp, I rolled the dice it was the resistor, and came out on top.
Thanks again for the help.
Old Jan 23, 2013 | 08:31 AM
mtroxel's Avatar
Don't know where you live, but it's 9F here right now. Bad time of the year to have heater problems. Glad you got it.
Old Jan 23, 2013 | 08:37 AM
ch19251's Avatar
I live in Cary NC, just outside of Raleigh, and yes it was very cold this AM, so I got that heater fixed just in time. I did have to drive for about a week with no blower and the windscreen fogging up was actually pretty bad.
My backup car is 1964 Triumph TR4 which the heat works pretty well in, partially because you basically sit right beside the motor, so she got some extra use lately.
Old Jan 24, 2013 | 01:38 PM
lespaul2510's Avatar
This happened to me as well, I think the unit had something spilled on it. Mechanic ended up replacing the control unit.
fmedina22
Dec 23, 2008 08:50 AM
mollusc
Oct 27, 2007 05:06 AM
tenaciousd
Feb 1, 2007 10:44 PM
t3bod
Oct 25, 2006 02:29 PM
mikeysentra
Jan 7, 2006 06:18 PM
