help
Old May 30, 2009 | 04:29 PM
kloepfer_3's Avatar
Default help
oil light comes on my disply. i just did a oil change. help
Old May 30, 2009 | 05:04 PM
hiwords's Avatar
no need to post 2 times about the same problem bro. double ceck your oil level
Old May 30, 2009 | 05:12 PM
kloepfer_3's Avatar
i know sorry about that. i was typing it on my phone. i was trying to find a way to delete it. so when i recheck the level and its good. then what.
Old May 30, 2009 | 05:35 PM
hiwords's Avatar
check the connection on the oil level sensor. the sensor should be on the oil pan
Old May 30, 2009 | 05:37 PM
kloepfer_3's Avatar
ok. thanks
Old May 30, 2009 | 05:57 PM
ghost6303's Avatar
this could be a dumb question but some people still forget.... did you remember to: put the drain plug and filter back on tight enough? fill the car with the proper amount of oil, and oil of the correct type? (i know of people who just plain forgot to refill it with oil after the car was back on the ground. not a good thing)
Old May 30, 2009 | 06:45 PM
kloepfer_3's Avatar
i took to a shop that works on european cars. they change my oil. so i hope they know what oil.to use
Old May 31, 2009 | 02:37 AM
ghost6303's Avatar
oh you had it done at a shop and then the light came on? just take it back there and make them fix it. i thought you did it yourself.
Old May 31, 2009 | 01:13 PM
kloepfer_3's Avatar
if it is a the sensor on the oil pan. how much is it? is that something i could just do myself.
Old Jun 1, 2009 | 12:04 PM
kloepfer_3's Avatar
how bad is it to drive the car with that popping up?
