help
Old Oct 28, 2014 | 11:36 AM
jrwslw's Avatar
Default help
Hi
I hope I am in the right spot. I have a 2000 audit A4 Turbo. Just changed all coil packs but still have ruff idle and low power. Any ideas where I can go from here???
Old Oct 28, 2014 | 03:51 PM
armtjays's Avatar
jrwslw you should clean your MAF sensor. *Make sure you disconnect one of your battery leads before unplug MAF connector. Let MAF sensor dry thoroughly before reinstall.
If that doesn't work, try cleaning the throttle body.
As a matter of fact, I'll do both at the same time. While MAF drying, I'll do throttle body cleaning.
