Help with borla exhaust install on 2000 1.8t!!! Help fast!!
Old Jan 12, 2012 | 12:17 AM
bomber495's Avatar
the car caught fire in the engine bay and burned them up im guessing since they werent on the car... also I found that they are actually bilstein f4-be3-2669 shocks with intrax 10-060 rear 242 springs. does anyone know what intrax springs match the rears I have or what other brand springs would match these and also the same for the bilstein shocks. Im nervous I just wasted some money...
Old Jan 12, 2012 | 07:26 AM
CCA4's Avatar
Originally Posted by jonbonesjones
my bad chris. Op made a thread about his missing front coils. didn't realize it was in here as well.
Ain't no thang
OP, I honestly dunno what to tell ya about the coilovers besides try contacting Bilstein.
Old Jan 12, 2012 | 08:52 AM
jonbonesjones's Avatar
Moderator
maybe try bilstien struts, with a set of springs to match the rear then use a diy coil over kit
Old Jan 30, 2012 | 05:57 PM
bomber495's Avatar
ok people I finally got the downpipe to cat gasket today and tried to get this installed. I ran into a problem... I took out the air box so I could get to the cat bolts easier but the 3rd bolt on the bottom is in a horrible spot!!! I couldnt figure out any way to get it undone. Idk if Im going at this the correct way. It seems like I should just cut the damn thing and use the stock sleeve and make this easy. Whats the advantage of using the borla down pipe? Its the same ID as the stock so i cant imagine it being any different right? Correct me if im wrong please!
Old Jan 31, 2012 | 07:48 AM
CCA4's Avatar
YGPM.
That's why I suggested removing the cat/downpipe as one piece through the top of the engine bay. Much easier that way.
Old Mar 29, 2012 | 05:01 AM
10kRedline's Avatar
Hey, I know that its been months now but I want to know your progress, how did you take the cat and down pipe out? I'm having the same problem, can't takeit out from the engine bay.
candycane84
Jan 11, 2008 01:13 PM
Bogie
Oct 17, 2007 11:41 AM
Bogie
Oct 13, 2007 05:28 PM
A4Rollin
May 24, 2007 10:09 AM
b52000a4
Nov 14, 2006 11:29 PM
