Help with code
Old Nov 10, 2008 | 07:15 PM
brimhall99's Avatar
Default Help with code
Has anybody had a code p1556 Charge pressure control negative deviation? I have terrible boost problems in the lower gears.
Old Nov 10, 2008 | 07:24 PM
akielb's Avatar
#1 search
took me less than a minute to find a post linked to this
http://wiki.ross-tech.com/index.php/17964/P1556/005462
Old Nov 10, 2008 | 08:08 PM
brimhall99's Avatar
thanks
Old Nov 10, 2008 | 08:37 PM
brimhall99's Avatar
About the n75 valve, I seem to get full boost in the higher gears, wouldn't that make it unlikely to be that?
Old Nov 10, 2008 | 10:54 PM
onepoint8tee's Avatar
I used to have that code and limp mode every time I'd take it past 5k WOT through every low gear 1st-3rd in my 2000. After a restart it was fine until I did it again. Basicaly it means the ecu is seeing less boost than it requested. You could try removing and cleaning your map sensor (on top of the ic) or it could be a faulty n75. This started happening after I got chipped. I never did figure it out, but I hardly ever drive wot to red line through every gear like I used to either. Seemed to be less likely to happen when I was using the n75 race valve and never happened when i used a mbc (but the mbc gave me other issues.) Good luck.
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
snowman_w900
Apr 14, 2010 12:30 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
tonym
Jun 14, 2006 03:49 AM
