Help with DTC code!!!
Old Jun 30, 2008 | 06:23 PM
CRAZYHAWK's Avatar
Default RE: Help with DTC code!!!
Check
www.ecstuning.com
for a remanufactured MAF.
Old Jul 1, 2008 | 05:20 AM
Speed_Munkie's Avatar
I agree that resistance readings would be best to test the MAF if anyone has any known working values to check against that would help, also the pin out for the sensor would help. You mentioned water around the ECU water box? Where do i need to look to check this?
Old Jul 1, 2008 | 02:01 PM
techbod's Avatar
ignition off remove MAF multiplug resistance between 1 ( wire side ) and ground should be zero resistance,
checking for power
multiplug disconected switch ignition on and crank for a second - battery voltage between 3 and ground and do same with pins 1 and 3,
testing while engine running multiplug connected back probe the wires,
engine idling clotage should be 1.1v approx
at 3000 rpm voltage should be 1.9v approx
Old Jul 2, 2008 | 12:25 AM
Tweaked's Avatar
ORIGINAL: Speed_Munkie
In the cowl, below the windshield where the battery sits. The ECU is on the driver's side.
But run Techbod's resistance values (above) against yours.
Old Jul 2, 2008 | 06:23 AM
ORIGINAL: techbod
checking for power
Thanks alot i will test it once i get home from work, you guys truly are a fountain of knowledge!
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
snowman_w900
Apr 14, 2010 12:30 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
tonym
Jun 14, 2006 03:49 AM
