Help with engine swap.
Old Jun 14, 2010 | 03:33 PM
red4t's Avatar
Default Help with engine swap.
I have 01 a4 1.8t that had a AWM engine. I found a few used low mileage engines around for decent prices but none of them are AWM, I know that the AWM has VVT, so how would i or can i delete the VVT?
Old Jun 15, 2010 | 12:21 PM
R.A.I. Motorsport's Avatar
Former Sponsor
you need a 1.8T from 01+. VW or Audi it doesn't matter, just transfer your accessories over. Reason being is that you have the newer 06A block while pre2001 uses the older style block. You can use a non VVT tensioner but you will need software to write it out. Just get a small port head, they float around quite often, and came on 2000+ Audi/VW. They are also the same
Old Jun 17, 2010 | 02:34 PM
red4t's Avatar
Ok thanks. So if i dont end up with a VVT head i will need my ECU flashed? I have this guy telling me that i can just leave it unhooked and it will not throw a code or affect the runnability which i find hard to believe?
Old Jun 17, 2010 | 04:59 PM
Mike-2ptzero's Avatar
It will throw a code.
Is the head that was in the car bad?
Old Jun 18, 2010 | 12:08 AM
hiwords's Avatar
haha it's an audi, it'll throw a code for any little thing. like mike is implying, if it's just the head, you don't need to replace the whole engine. the crank usually doesn't go bad.
Old Jun 18, 2010 | 10:20 AM
Former Sponsor
If you have a VVT car and unplug VVT, it will throw a code. You can just swap your VVT tensioner into the non VVT head.
rwhaley205
Mar 1, 2014 10:31 PM
curtmon03
Mar 19, 2012 08:35 PM
curtmon03
Oct 4, 2011 07:49 PM
lacadie17
Jul 11, 2010 08:06 PM
8urVtec
Mar 11, 2006 08:40 PM
