help installing short shifter?
Old Dec 20, 2011 | 02:14 AM
alexmurphy's Avatar
Default help installing short shifter?
I'm going to install an off-brand b&m shifter (which was recommended to me on this very forum) and the B&m instructions say that some cars may need the entire center console to be removed. I need to know if that applies to my car and how to go about removing the console.
The instructions also tell me I need to lubricate certain parts of the shifter before installation. what should I lube with? I'm lost as to whether it means WD40 or more industrial grease.
I may have more questions as time progresses, and I am hoping to install this before this weekend.
For the record, here is the shifter I bought (mine did not come with a **** and some of those parts)
AUDI A4 96-03 S4 00 01 SHORT THROW SHIFTER+S SHIFT **** | eBay
Lastly, if you bought a shift **** online that you particularly like, please share. My (stock) shift **** is too wide, and it will bother me with a short shifter, im sure.
Old Dec 20, 2011 | 06:12 AM
cnigro1279's Avatar
Default Here..
Found this for you: JHM Short Shifter Install B5 A4 Part 1 - YouTube
and if you search hard enough on the inter-webs, you will find a written tutorial as well.
The video seems pretty good..
Hope this helps you out..
Old Dec 20, 2011 | 06:22 AM
cnigro1279's Avatar
Old Dec 20, 2011 | 08:46 AM
CCA4's Avatar
I've installed this shifter on a 97 2.8 with push-down reverse, and a 2001.5 1.8T without push-down reverse, and didn't remove the console for either one. It's absolutely possible to do it that way.
If you have big hands or not a lot of patience, you might think about it, just because it'll open up some more space for ya, but it definitely isn't necessary.
Don't use WD-40 to lube the pieces, it isn't designed for that. Use white lithium grease
jibberjive
Feb 24, 2009 12:57 AM
jibberjive
Jan 9, 2009 09:16 AM
SAudi
Dec 12, 2006 02:18 AM
EvilA4
Jun 8, 2005 04:01 PM
viagra
Sep 21, 2004 10:28 PM
