help installing turbo timer!!
alright so i just got my turbo timer in today. off brand so the instructions are a little weird. pretty good with electronics so i know i acn put it in without a problem just need a little help finding right wires and everything.
alright so i have 3 wires going into a harness, which im sure ill have to cut the end of the harness off and splice the wires together cause i dont want to spend money on harness to plug and play lol. three wires agoing into the end of the harness clip consist of these colors. red (power). Blue (Acc or Ig2? dont know what that is) and yellow (IG gessing ingnition?) then i have a black wire (ground) and Brown wire for the E-brake. I need to know what wires i have to connect the red. yellow. blue. and brown wires to. and how to get to those areas. thank you for the help!!!
Well the only wire I remember that gave me trouble was the ebrake, its under the little cap behind the arm rest, there will be two wires, one brown and one brown/white, I dont remember which one it is, just try both. sorry if I coulnt be of a lot of help, but thats all I remember..
which turbo timer did u get. mine took me like 30 min to do
i used this writeup just skipped to the wiring part cause i mounted mine in a different spot..
http://www.audiworld.com/tech/elec98.shtml
and 40 secconds is really more than enough to keep it running... my friend lets his sti run for 30 sec and his turbo is bigger than my head...
