Help Need Diagnosing
Old Nov 8, 2012 | 02:45 PM
CCA4's Avatar
OP, where are you located? There are plenty of indie shops that should be higher on your list than the dealer.
Old Nov 8, 2012 | 04:13 PM
rynmthw3's Avatar
Do you feel as though a complete motor swap would be better? I have priced a few from different online sites I'd be looking at about $1,500 for a motor under 100K. Im not sure how trustworthy the sites are, they all claim to test and run engines before posting.... has anyone bought a motor off-line?
Old Nov 8, 2012 | 04:15 PM
rynmthw3's Avatar
the vehicle is located In North Adams MA 01247
Old Nov 8, 2012 | 04:45 PM
jonbonesjones's Avatar
Moderator
you can get engines cheaper and a motor swap isnt a goodi idea because its goign to have the same problem as yours eventually. you need to figure out the problem and go from there.
Old Nov 8, 2012 | 07:25 PM
rynmthw3's Avatar
Well as im sure you can tell from the threads....Im not an audi expert, I've worked with cars before but never changed a motor or even a timing belt. What kind of diagnosis would determine what caused my timing belt to jump a tooth or how will I be able to find the culprit to determine what will fix my problem?
Old Nov 8, 2012 | 07:38 PM
Moderator
a leakdown test or a visual inspection, search some there are marks on the cam and crank gears that will help tell. a leakdown test will let you know if your valves are sticking open.
GoremanX
Sep 18, 2012 10:04 AM
Warfare S4
Jun 21, 2012 06:53 PM
hauptjr
Apr 18, 2010 09:11 PM
Texas_Pete
Aug 24, 2008 07:44 PM
darm87
Sep 21, 2007 02:59 PM
