Help!! P1136 & P0441???
I failed my smog test due to a check engine light being on and when i scanned it with the vagcom the codes that came up were:
17544 - Fuel Trim: Bank 1 (Add)
P1136- 35- 00 System too Lean
16825 - EVAP Emission Control Sys
P0441- 35- 10 Incorrect Flow - Intermittent
I am unfamiliar with these codes so any suggestions will help... Im not sure if this is related, but the car also drops in idle and goes back to normal when i first start it and randomly while driving after i take it out of gear, (ie: when approaching a stop sign)
Could one of these codes be caused by a clogged fuel filter or possibly a failing fuel pump?? any help is greatly appreciated! thank you!!
Derek
Derek
AudiTurbo
Jan 10, 2015 08:05 PM
