Help!! P1136 & P0441???
Old Dec 29, 2012 | 05:59 PM
lovemyaudi1.8t's Avatar
Default Help!! P1136 & P0441???
I failed my smog test due to a check engine light being on and when i scanned it with the vagcom the codes that came up were:
17544 - Fuel Trim: Bank 1 (Add)
P1136- 35- 00 System too Lean
16825 - EVAP Emission Control Sys
P0441- 35- 10 Incorrect Flow - Intermittent
I am unfamiliar with these codes so any suggestions will help... Im not sure if this is related, but the car also drops in idle and goes back to normal when i first start it and randomly while driving after i take it out of gear, (ie: when approaching a stop sign)
Could one of these codes be caused by a clogged fuel filter or possibly a failing fuel pump?? any help is greatly appreciated! thank you!!
Derek
Old Dec 30, 2012 | 06:38 PM
zaboomafoo1212's Avatar
I would say vacuum leak and dead SAI pump. I think that P0441 code is related to that. I ran a P0411 when mine went out. Somebody correct me if I'm wrong.
Audi_Sky_77
Mar 29, 2015 06:03 PM
ellamejia2001
Apr 3, 2013 07:05 PM
KingBenelli
Jul 25, 2008 07:45 PM
Jorgito
Aug 1, 2007 09:41 PM
