Help Please asap
So recently I have been having an issue of loosing coolant. It seams like I have to add more every other to every few days. And not once has there been a puddle or any sign of a leak under my car. I ended up putting the car up on some jacks and trying to see where the possible leak may be. Once I got under there I noticed that on the right hand side of the car some droplets were forming of coolant but I was no able to see where they were coming from. The best I could do was see a possible pool of coolant on the rear of my engine under the intake manifold.
Then in the process of being under my car i noticed this broken hose, which connects in to the head;
What is that hose for? It looks like it carries oil, but i've had no oil leaking onto the ground.
Thanks
Thanks
Is that the oil cooler line? you need to learn to use the focus ring on your camera....
But if that's the oil cooler line I think you should have coolant pouring out of there and it would be very obvious. Try taking a pic from a little further back then a close up- and for god's sake focus!
