Help - rear wheel bearing
Old Feb 26, 2008 | 10:08 PM
hartsoe1's Avatar
Default Help - rear wheel bearing
Everything was going great on the 2000 a4 1.8 atw rear wheel bearing until the tapered friction bolt on the lower control arm (the one where the emerg brake line and the regular brake line go around) started spinning with the 19 mm nut. What to do?
Old Feb 27, 2008 | 08:25 PM
Lazer Viking's Avatar
Default RE: Help - rear wheel bearing
what are you talking about, the only bolt on the bottom you have to take off is the one for camber adjustment, and that has nothing to do with the ebrake
Old Feb 27, 2008 | 09:10 PM
hartsoe1's Avatar
Poor description on my part. Not the camber, but the tie rod assembly (which travels between the two brake lines - that was the reference when I didn't know that it was called the tie rod). That nut wouldn't come off, the stud was spinning in the ball joint. I just took it apart back at the toe adjustment and took the whole thing to the shop to get the bearing pressed - so they took it apart for me, too. When it went back together, I could compress it enough to get it to hold so I could tighten it. I was back driving it tonight. The car is oddly quiet now with new bearing....
Old Feb 27, 2008 | 10:29 PM
hiwords's Avatar
the rear has no tie rods buddy.
Kyle_vdk
Jan 11, 2014 10:25 PM
Nevalite
Feb 14, 2011 07:59 AM
palendromer
Jul 10, 2007 01:59 PM
Anybodykilla
May 3, 2006 10:46 PM
skidplatexa4
Nov 21, 2005 02:47 PM
