Here's the scoop--Need help
Old Aug 31, 2010 | 10:15 AM
skurl35's Avatar
Default Here's the scoop--Need help
Just got the car out of Audi service. I new I had some kind of oil leak, but didn't know how bad.
Needs Valve Cover Gaskets and cam seals---$614
Needs both rear diff seals--$686
Wsaher fluid pump, upper--$416
Not a DIYer per se, but these sound like decent size jobs...Any thoughts, suggestions etc???
Old Aug 31, 2010 | 10:18 AM
CCA4's Avatar
Valve cover gaskets are easy, definitely a DIY. Cam seals are a bit more tricky but definitely still doable. The washer fluid pump is absolutely a DIY, especially with a $416 estimate. Never done the rear diff seals or heard of them being bad, for that matter.
Old Aug 31, 2010 | 10:38 AM
skurl35's Avatar
Thanks for your quick reply. Is there a site I should go to to order the parts? And isn;t there a DIY website as well?
Old Aug 31, 2010 | 11:11 AM
chocalotstarfish's Avatar
Super Moderator
We have a diy section on the forums. Also audidiy.com is really good. I agree with what cca4 thats all diy-able not sure about the read dif either haven't done one.
Old Aug 31, 2010 | 12:52 PM
Dallas09's Avatar
I think they are referring to the axle seals on the rear diff. They usually leak so slowly it just makes more sense to top off the fluid every couple of years.
Old Aug 31, 2010 | 06:49 PM
joenelson7687's Avatar
I order stuff from ecstuning.com and I have had nothing but great experiences.
Audacity
Jan 17, 2010 11:10 PM
VaTTer
Feb 14, 2008 08:54 AM
