HEY GUYS IM BACK!! (and have some codes)
Old Sep 5, 2013 | 06:50 PM
DOC_DEPALMA's Avatar
Default HEY GUYS IM BACK!! (and have some codes)
In America.
And my car is a ******** still lol.
VCDS-Lite Version: Release 1.2
Thursday, 05 September 2013, 18:34:43.
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76 ,77
Address 01: Engine Labels: 8D0-906-266.LBL
Controller: 8D0 906 266 B
Component: 2,8l V6/2V MPI OBD2 D02
Coding: 01202
Shop #: WSC 02324
VCID: 2B2984AFCA1D
6 Faults Found:
17920 - Intake Manifold Valve (N156): Short to Plus
P1512 - 68-00 - Cylinder 1
17658 - Shareware Version. To Decode all DTCs
P1250 - 95-00 - Please Register/Activate
18014 - Shareware Version. To Decode all DTCs
P1606 - 68-00 - Please Register/Activate
16688 - Cylinder 4: Misfire Detected
P0304 - 95-00 - Unknown Error Elaboration
16689 - Shareware Version. To Decode all DTCs
P0305 - 95-00 - Please Register/Activate
16684 - Shareware Version. To Decode all DTCs
P0300 - 95-00 - Please Register/Activate
00771 - Fuel Level Sensor (G)
30-00 - Open or Short to Plus
Old Sep 5, 2013 | 06:56 PM
So up above are the codes and here are the symptoms.
She's got a rough start and idle, feels like I'm sitting in a humvee/helicopter. After I let it warm up it becomes a bit more stable. I think you would call it a hard start? It seems a lot more rough with lower RPMs and I can hear some clink clanking. As RMPs increase it's a lot steadier as I said before. It's almost an art to keep it running when I put it in gear, and when it stalls it stalls HARD.
Please post any advice knowledge wisdom or **** you's below. Thanks for the help guys I can't wait to finally get this bastard mobile and come to a meet WITH FREE BEER FOR YOU
Old Sep 5, 2013 | 08:55 PM
bshusted's Avatar
Coding: 01202
Shop #: WSC 02324
VCID: 2B2984AFCA1D
6 Faults Found:
17658 - Fuel Level Too Low
18014 - Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction
16689 - Cyl.5 Misfire Detected
16684 - Random/Multiple Cylinder Misfire Detected
Added the missing codes for you.
With the random misfires, I would start by looking for a vacuum leak. This would explain the rough idle, etc. Start with the vacuum hoses. If the originals have not been replaced, I would preemptively replace all of them anyway. The braided cloth ones don't seem to last very long. I don't know about the 12v engines, but about 6ft was plenty to replace all of them on my 30v. The diameter should be 3.5 mm. You can get silicone line from the web if you've got time or just run to a parts store and get something close enough in English sizing.
Look for other leaks in the intake tract. PCV hoses, TB elbow, anything else downstream of the MAF.
Old Sep 6, 2013 | 03:30 PM
Smile
Makes sense to me. I've already replaced the vac lines with the silicone kind, but the routing/placement is in question. I'll look into it. Thanks man.
numlock4045
Jan 26, 2012 11:46 PM
cjm32
Jun 4, 2010 01:32 AM
rustlerboi1052
Aug 15, 2009 05:02 PM
jcyj2
Apr 30, 2008 06:49 PM
