hi guys
Old Jun 24, 2009 | 08:49 PM
dallas_chris's Avatar
Default hi guys
i'm new here. I awn an audi but it's broken like my *****. does anyone know how to fix this problem?
It's a 99 model.
thanks yous for your time.
Old Jun 24, 2009 | 08:58 PM
ObnoxiousDrunk's Avatar
HAHAHAHAHAHAHAHAHAHAHAHAHA
seriously what's the issue with the car
Old Jun 24, 2009 | 09:07 PM
Sorry, I had just put up a post asking for help... walked away and a friend decided to make a post of his own since I left it open. Every bit my own fault but he will defintly have it come back to him. I must admit, funny! hahahahahahahaha. Here's what I need help with.
____
First off I'll say I havn't much of a clue as to how to work on cars but I've been able to figure out some of the following..
I have a 1997 A4 2.6 that starts to overheat only when I have the a/c on. I've checked to make sure the fans are both working properly and they are. When I'm driving the car it doesn't have a issue and blows cold air. When I stop for 2-5 minutes at a light I'll feel ambient warm air from the a/c and the temp will start to rise. Any ideas on what to check next?
I assume that the next step should be to flush the radiator, check the thermostat, and then if all is good there change the water pump. Is that right or am I missing something?
Where excatly is the thermostat located on the car? pictures or diagram would help since I'm a idiot when it comes to this stuff..
Thanks in advance for your help!
Old Jun 24, 2009 | 09:11 PM
I'm no expert on a/c and cooling but I'm sure someone else can help you out.
Thanks for the laugh.......
Old Jun 24, 2009 | 09:38 PM
jiggleo's Avatar
I'm too drunk to remember what they call that fan but it's the one behind the fans that actually cools the engine itself. should have a clutch on it. That'd be my first guess.
Old Jun 24, 2009 | 09:56 PM
It's not either fan.. there are 2 and they both work perfect.
Any ideas where the thermostat is?
Old Jun 24, 2009 | 11:52 PM
ghost6303's Avatar
a coolant flush couldnt hurt. the thermostat wouldnt be related to only the a/c, the car would run cold of hot all the time if the thermostat was stuck open or closed. its not the water pump. you might just need a refrigerant recharge.
Old Jun 25, 2009 | 12:23 AM
those are the same conclusions I'm coming to as well with the pump and thermostat. My only question is why would the car overheat only when the a/c is on??!?!? and only when I'm in traffic & not driving down the road...?!?!?!
Old Jun 25, 2009 | 01:39 AM
Tweaked's Avatar
You might have a bad fan clutch or slipping belt causing the mechanical fan not to push enough air or possibly a bad fan control module causing the electric fan not to kick into its high-speed mode to cool the condenser while sitting in traffic.
NOLA
Jan 23, 2009 05:21 AM
VaTTer
Feb 14, 2008 08:54 AM
turbo kraut
Feb 10, 2007 05:16 PM
lou
Oct 17, 2006 05:34 PM
Nads07
Oct 13, 2006 03:23 PM
