hissing noise...
Old Dec 4, 2008 | 11:11 PM
Jc61990's Avatar
Default hissing noise...
ok so today, i got out of my car. and i have a turbo timer so my car stays running for a while.. during that time i heard this loud hissing. almost like a popped tire.. i was like wth is that my tires were fine. it was coming from the engine bay. so i popped the hood and checked around. then my engine turned off and the hissing was gone... so i started it back up and check around.. it was coming from above the throttle body. i think it was some kind of valve that has a little nipple thing on the under side that was sucking in air.. is that normal or should i replace it.. i took a picture of it. its kinda dark but you get the picture
Old Dec 5, 2008 | 12:29 AM
Jc61990's Avatar
bump..
Old Dec 5, 2008 | 12:32 AM
hiwords's Avatar
can you post a slighty smaller and clearer pic and circle the hose pls? try duct taping what it is if you can reach it
Old Dec 5, 2008 | 12:36 AM
Jc61990's Avatar
done.
looks like the PCV valve..
Old Dec 5, 2008 | 01:27 AM
DÌEGØs AÜD!CTIØN's Avatar
i have a 2.8 so idk much about ur car but maybe a [vacuum]hose got loose and came off the nipple.... so look a round or something idk im just guessin lol
Old Dec 5, 2008 | 11:23 AM
Jc61990's Avatar
heres a pic of that valve
theres nothing connected to the bottom nipple. should there be? its very loud and makes me think my tire is popped
Old Dec 5, 2008 | 11:54 AM
hiwords's Avatar
ya common, problem. either replace it or tape the **** out of it lol. you can usually feel the air where it's leaking so you can find it easily
Old Dec 5, 2008 | 12:18 PM
Jc61990's Avatar
its sucking in air through the bottom line... i was talking to some 1 else and he said there should be a hose connected to it.. i just looked in my engine bay for a loose hose and didnt see anything
Old Dec 5, 2008 | 12:22 PM
oh so i was right!! ?
hiwords's Avatar
o there's a hose missing? there should be a hose connected. look harder and pull things around a bit. you'll find it, if not have someone else take a look. plug it up in the mean time. you don't want dirt in the system
