Hose location
Old Sep 29, 2013 | 06:47 AM
rmr1499's Avatar
Ya already have code that's why trying to fix got emission test to pass
Old Sep 29, 2013 | 06:53 AM
rmr1499's Avatar
And idk if that's the correct thing either in the diagram it shows that vacuum line coming from back side of selonid and going to the canister the line is on the opposite site of the selonid the right side but the diagram doesnt show that anywhere
Old Oct 5, 2013 | 10:43 AM
rmr1499's Avatar
Anybody. That isn't the right one the diagram even shows it isn't that's off the wrong port I need the one that's pointing towards the drivers side fender
Old Oct 5, 2013 | 10:48 AM
mtroxel's Avatar
The diagram tells you it's in the left fender. And you have an empty hose pointing toward the left fender.
Old Oct 5, 2013 | 11:28 AM
rmr1499's Avatar
No the diagram show the hose off the back side of tht selnoid gong towards the firewall
Old Oct 5, 2013 | 11:52 AM
mtroxel's Avatar
That's the way diagrams read when they aren't big enough to show you the whole picture. Look at the note on number 12. "Installation location: Under wheel housing liner in front left wheel housing."
Old Oct 5, 2013 | 03:17 PM
rmr1499's Avatar
Ya by the hose it set is in different port
Old Oct 5, 2013 | 03:50 PM
  #18
rmr1499's Avatar
Typo
That hose from the breather it goes to the rear of the selonid not the front of the selonid I need the front
Old Oct 6, 2013 | 12:34 PM
  #19
Kamil`'s Avatar
mtroxel has provided you with a good diagram. The original should be located on the passenger side of your hood.
And in regards to the vacuum canister you are missing.. you probably didn't swap it during the "swap", or like you said, it wasn't there, but I doubt it.
I know that the vacuum canister on the 30v plugs into the actuator solenoid on the drivers side of the engine.
The passenger side actuator controls the EGR system and I believe the driver side actuator controls DV operation.
Old Oct 6, 2013 | 06:00 PM
  #20
rmr1499's Avatar
Ya but the diagram only shows 2 hoses off the selonoid so where's the third port on the diagram. It's not there.. And i took both cars apart neither had them all they had das the canister in drivers fender closer towards door
