Hotchkis sway link
Old Oct 27, 2014 | 08:08 PM
mtroxel's Avatar
Default Hotchkis sway link
Is something wrong here? You can see the angle of my front Hotchkis sway bar versus the link coming down from the arm. It's very hard to get that bolt into the sway bar, and when I do there is a lot of stress going through those bushings, even at rest. As you can see, this one is shot and it's only about 11 months old.
Is this just the way it is with these?
Old Oct 28, 2014 | 11:32 AM
CCA4's Avatar
Is that one of their adjustable sway bars? Maybe a less aggressive setting would help?
Old Oct 28, 2014 | 12:17 PM
mtroxel's Avatar
Nope, not adjustable. Just got back from my indy Audi mechanic friend, he's pretty baffled too. No way can you bend that sway bar, the arm above is an Audi brand 4d0407155. He's guessing it might be the aftermarket sway link. I've got two new ones coming. We'll see.
Old Oct 28, 2014 | 02:17 PM
CCA4's Avatar
Interesting. Well good luck man, I hope the new sway bar links fix the problem.
Old Oct 29, 2014 | 09:04 PM
mtroxel's Avatar
Swapped the links today. Had to work to get them on, they just don't line up great. Here's the Audi control arm and the Hotchkiss bar. There's a jack under the steering knuckle and it's lowered so the whole suspension is at ride height. Note the difference in angles between the end of the sway bar and the ear on the aluminum casting control arm.
Oh, here's what it does to a sway link after 23,000 miles.
Old Oct 31, 2014 | 12:21 AM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
What RSB are you running? You might just try switching back to the stock front bar. These cars really don't need an upgraded front sway bar. The stock bar generally balances quite well with an upgraded rear bar.
I'm running an S4 RSB and stock front bar and I plan to upgrade to an 034 RSB at some point.
Old Oct 31, 2014 | 07:43 AM
mtroxel's Avatar
I'm in the dark. What's an RSB?
Old Oct 31, 2014 | 11:35 AM
MetalMan's Avatar
Rear Sway Bar.
Old Oct 31, 2014 | 12:42 PM
mtroxel's Avatar
Originally Posted by MetalMan
Rear Sway Bar.
Well don't I feel like a dumb newb!
Hotchkis rear bar out of the same kit. The whole thing gives a nice suspension upgrade, but I'm starting to feel like I've just had too much suspension popping noises since I did this.
Tweaked
Jan 11, 2014 09:36 PM
hotgue
S4
May 30, 2013 10:39 PM
JETSPEED333
Feb 29, 2012 10:50 PM
Tweaked
May 24, 2008 01:08 AM
AteUrV8
Apr 26, 2007 12:04 AM
