How to check/measure vacuum
Old Feb 7, 2010 | 12:47 PM
vtraudt's Avatar
Default How to check/measure vacuum
As part of the trouble shooting (reduced power), I am sure checking the vacuum (potential leak?) is one of the first things.
I have a handheld pump/gauge unit (Autozone).
Can someone instruct me where to hook it up?
I have read somewhere that I should expect 18 or so inHG?
Thanks.
Old Feb 7, 2010 | 02:44 PM
bbboy's Avatar
Member
Make a T connector like this guy here, pict. 14
http://www.ray-cuthbert.com/audi/how...oam/2009_10_19
and attach it to the intake manifold blue hose (ref. this link) on the front of the engine block (like in pic. 6). Connect your vacuum gauge to the T and start the engine. Let it run for 5-10 min, it slowly build vacuum and mine is at about -18" when hot.
Old Feb 8, 2010 | 04:58 AM
Quattros's Avatar
^^great info
Old Feb 8, 2010 | 11:06 AM
McGovs2.7TB5's Avatar
A boost gauge should be one of the 1st mods anyone with a turbo car should do.
Old Feb 8, 2010 | 11:30 AM
vtraudt's Avatar
It is going to be ordered soon; need to decide on style and location (behind the steering wheel or pillar pod).
Can I splice a pressure gauge temporarily in (for example with a T) somewhere convenient in the engine bay?
Old Feb 8, 2010 | 12:42 PM
The vac line nipple near the front of the intake manifold should work. Thats where I tapped for my gauge.
Old Feb 8, 2010 | 01:03 PM
vtraudt's Avatar
This one?
Old Feb 8, 2010 | 02:13 PM
either one will work, I personally used the one the nearest the front of the car.
Old Feb 8, 2010 | 03:47 PM
vtraudt's Avatar
Default Vaccuum
Hooked it up today. With warm engine: -20 inHG idle, steady. So I am good on the vacuum side, no leaks, right?
Old Feb 8, 2010 | 05:09 PM
Ya thats where it should be
