how do I change my catalytic converter?
Old May 1, 2008 | 12:39 AM
porsche659's Avatar
Default how do I change my catalytic converter?
How hard would it be to change my catalytic converter?
Old May 1, 2008 | 01:27 AM
FASTER's Avatar
Tech Slut
Default RE: how do I change my catalytic converter?
is your car a 1.8 or 2.8?
Old May 1, 2008 | 02:57 AM
SuprA4's Avatar
https://www.audiforums.com/m_755733/tm.htm (does not specify)
http://audizine.com/forum/showthread.php?t=101953 (1.8t)
Old May 1, 2008 | 02:16 PM
porsche659's Avatar
It's a 1.8 liter
Old May 1, 2008 | 03:20 PM
chaos92287's Avatar
the second link suprA4 posted. the cat->dp bolts are the biggest PITA. soak them in pb blaster the night before you start this and be prepared to curse a lot
Old May 1, 2008 | 04:47 PM
SAudi's Avatar
well there many DIY for the 1.8t but if you have the 2.8 your better off getting aftermarket cats an djust cutting and welding them on, the cats are conntected fromt eh downpipe (starts right after the exhaist manifold) and goes all the way down to the y-pipe which can be a PITA to get off, all in all look at about 400 minimum for the cats (each) and about 3-500 in labour.
Old May 1, 2008 | 05:36 PM
kavitz's Avatar
If you do decide to do it by yourself make sure you have u-joint extensions, the cat to downpipe is no bueno, and when u do get that out my advise to you is put the testpipe and downpipe together before you install it, it makes life a lot easier.
Old May 1, 2008 | 05:38 PM
kavitz's Avatar
cat*
Old Aug 30, 2013 | 12:14 PM
justleloman's Avatar
1.8 2001 a4 audi
Old Aug 30, 2013 | 12:15 PM
Replace
