how do I change my catalytic converter?
https://www.audiforums.com/m_755733/tm.htm (does not specify)
http://audizine.com/forum/showthread.php?t=101953 (1.8t)
well there many DIY for the 1.8t but if you have the 2.8 your better off getting aftermarket cats an djust cutting and welding them on, the cats are conntected fromt eh downpipe (starts right after the exhaist manifold) and goes all the way down to the y-pipe which can be a PITA to get off, all in all look at about 400 minimum for the cats (each) and about 3-500 in labour.
If you do decide to do it by yourself make sure you have u-joint extensions, the cat to downpipe is no bueno, and when u do get that out my advise to you is put the testpipe and downpipe together before you install it, it makes life a lot easier.
