how to get to my throttle body?
Old Apr 30, 2012 | 01:57 AM
wtfs's Avatar
Default how to get to my throttle body?
after getting this code.
17916 - Idle Control Sys: Upper Regulation Limit Reached
P1508 - 35-00 - -
people suggested i do a tb cleaning but i cant get to my tb as its under part of my coolant reservoir and a load of pipes.
can i confirm if im looking at the tb? and how do i get to it?
sorry im really new to these
Old Apr 30, 2012 | 03:14 AM
Sheasta's Avatar
Umm i dont think ive ever seen under the hood of a car with this engine but it looks like thats the tb right to the left of the coolant reservoir.
Old Apr 30, 2012 | 03:23 AM
wtfs's Avatar
exactly my problem. its kinda hard to get to eh? looks like i have to take the whole collan reservoir out to get to it?
Old Apr 30, 2012 | 07:16 AM
jonbonesjones's Avatar
Moderator
this is because you live in america and thats a noon turbo 1.8. take everything in your way off, take the screws out of the coolant tank and move it out of the way, don't disconnect hoses, then remembering where everything goes and taking pictures, take on thing off at a time, probably one use clips so cut them and replace them all with screw on pipe clamps. there will be a bolt holding the intake pipe on then 4 holding the tb, disconnect everything and take it out. Your making it a lot harder than it is. theres harder **** to get at than the throttle body
Old Apr 30, 2012 | 08:47 AM
CCA4's Avatar
Wild, I've never seen up-close pics of a non-turbo 1.8 before. Make sure you do a TB alignment after you get everything all put back together or it will run like poo.
Old Apr 30, 2012 | 10:41 AM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Neither have I, I can't imagine how slow it is though. Damn.
Old Apr 30, 2012 | 12:10 PM
01quattro's Avatar
Drain the coolant, if its the same as the 1.8T, take off the bumper grill on drivers side, on the 1.8t there is a peice of rubber you need to pull back, but i think its there to direct airflow into the stock intercooler, you may or may not have the black rubber. Then there will be a phillips drain screw. Coolant reservoir tank is held in place by 3 screws, and then slide off 3 hoses i think it is, and it comes right out.
And yeah 1.8t without a chip and running full spec is slow, let alone 1.8 no turbo, i wonder if they offered it in quattro with that engine, that must be horrible. Lawn tractor accelerates faster.
Old Apr 30, 2012 | 12:34 PM
johnson90512's Avatar
I am about to do this same thing in the next couple of days...except I shall be doing it on the 2.8l so its in the very back of the damn engine and almost below it haha yay for me.
Old Apr 30, 2012 | 03:27 PM
Sheasta's Avatar
Does it have higher compression?
Old Apr 30, 2012 | 03:30 PM
jmarshall098's Avatar
make sure your air filter isn't clogged before you go through all this trouble!
