How many Bolts?
Old Aug 27, 2008 | 11:42 PM
SnowmanJon's Avatar
Default How many Bolts?
How many bolts hold the alternator on? I see the one on top and I think that there is one on the front under the pulley....is there another? And can you take it out without pulling the bumper out? Someone know where I can find a DIY for this thanks
JON
Old Aug 27, 2008 | 11:52 PM
auditech79's Avatar
Two bolts most of the time, they are also different sizes between the two. You can do it fine without removing the front end if its a 1.8T
Old Aug 27, 2008 | 11:57 PM
onepoint8tee's Avatar
2 bolts. You should be able to get the belt off without pulling the front end into service position in order to get that pulley off and access to the bottom alt. bolt. I think thats how it goes. Iirc the bolt for that pulley gets taken out from behind.
Old Aug 28, 2008 | 12:31 AM
hiwords's Avatar
if you have a 2.8, just unbolt enough bolts so that you can slide the front end forward like 5 inches. you don't need to take the bolt completely out, just wiggle it up and out
Old Aug 28, 2008 | 10:30 PM
SnowmanJon's Avatar
Yep it's a 2000 1.8T and special considerations?
Thanks
JON
vgo
Oct 14, 2010 10:27 AM
quattroforthewin
Sep 24, 2010 10:43 AM
patrixx006
Oct 13, 2009 12:26 PM
lovemyawdeee
Dec 18, 2008 09:47 AM
BLRzAUDI
Jun 20, 2006 03:33 AM
