How many miles/hp is the stock clutch good for.
Old Aug 23, 2010 | 06:50 PM
99a4wagon's Avatar
Default How many miles/hp is the stock clutch good for.
I have chip on 24psi and a exhaust and also 208k on the clock..When I boost over 20 psi seems to want to slip..
I dont know if its worn out or not holding..Any suggestions.
Old Aug 23, 2010 | 06:57 PM
joenelson7687's Avatar
Seems to want to slip? So it is or it isn't slipping.
Old Aug 23, 2010 | 07:00 PM
Msnickbroderick's Avatar
Actual WIZARD
You can never give a specific answer to this, because peoples driving habits are different. My moms jetta has gone 178,xxx with 2 clutches, but my dads integra (back in the day) would eat them at about 60k
Old Aug 23, 2010 | 07:14 PM
99a4wagon's Avatar
It slips for sure.
Thats why I asked..If a stock clutch is good for that power ill replace with oem if not Ill get aftermarket..But the prices are the same so I might as well get a aftermarket.
Old Aug 24, 2010 | 02:00 PM
99a4wagon's Avatar
I want to buy a clutch now. My max dollar amount is $550. What one should I get that will hold my mods in sig and leave a little room to play.
Old Aug 26, 2010 | 11:07 PM
99a4wagon's Avatar
Mjm says 276ft pounds.
Old Aug 27, 2010 | 10:32 AM
Mike-2ptzero's Avatar
You want an aftermarket clutch.
CM FX300 (360 ft lbs)- $590 shipped
SB Stage 2 HD-TZ or OFE (325 ft lbs) - $475 shipped
Old Aug 27, 2010 | 01:16 PM
theflash's Avatar
I got the South Bend stage 2 (which ever the kevlar one is). I'm only on a 2.8 30v, but it's really nice. It grabs a bit harder than stock, but definitely as easy or easier to drive daily as the OEM.
Old Aug 27, 2010 | 01:44 PM
There are 4 versions of the SB Stage 2
O - Organic (daily)
TZ - Kevlar (Endurance)
OFE - Organic/Feramic (Endurance)
DXD - 6 puck (Drag)
Old Aug 27, 2010 | 03:57 PM
99a4wagon's Avatar
Im going with mjms oem with sm fw. With my mods id be lucky to clear 200 ft lbs..Why spend more money when that one is rated for 275.
http://www.mjmautohaus.com/catalog/p...oducts_id=3135
