How to Program 2000 Audi A4 Keyfob
Just replaced new battery in fob. How to you program the keyfob in order to make it operational again? It's the wife car and if I don't get this going there will be no play for me tonight... I can guarantee that... Its a 2000 Audi A4.
This has been covered a lot, a little searching yields:
"You need both of your switchblade keys to re-program them, you can program up to five switchblade keys:
Take the key you do not want to program (if it already works) and put it in the ignition. Turn it one click forward.
Close and lock the drivers door with the second key with the window down (you can also do this from the inside of your car).
On the second key (the one in the drivers door) press the 'UNLOCK' button ONCE only, the lights will flash on the car, but the doors will remain locked
With the second key still in the drivers door, unlock then lock the door again.
Pull the key from the slot and also take out the key out of your ignition and than test the remote functions."
press and hold lock on keyfob and lock on door.
release door lock button, then release keyfob button.
repeat process for unlock buttons.
turn car ignition off and pull key.
try keyfob.
if it doesn't work, repeat steps above.
Is there anyway to test the fob itself?
Just to make sure it is even working? The fob that came with my 99 A4 looks, well, 18 years old. It's seen some ****.
I replaced the battery and am not having any luck getting it to do anything.
Thanks.
Jeremy
Thanks.
Jeremy
A4BOYS1-8
Jul 13, 2010 03:17 PM
2000, a4, audi, b5, battery, disable, fob, instructions, key, keyfob, program, programing, programming, reactivate, reprogram
