I have a problem and don't know how to fix it........?
Old Mar 9, 2009 | 05:14 AM
The Cowboy's Avatar
Default I have a problem and don't know how to fix it........?
Hello - I have an old 1995 2.4 A4 and its driving me nuts!
Its developed an issue which started a few months ago, at first it didn't happen too often but has recently begun to do it on a more frequent basis -
Basically when I turn the ignition the car will start up and rev briefly before the engine cuts off and dies - the problem is very intermittent - some times the car will fire up first time, some times it takes a few tries or some times it wont fire up at all but its always the same thing - the engine fires into life, sounds healthy then cuts off! But once the car has fired into life there is no issue, it runs and drives very smoothly.
I was thinking it could possibly be the fuel pump but I'm not entirely sure??
Thanks in advance for any responses.
Old Mar 9, 2009 | 08:15 AM
teamdaraptor's Avatar
Is it throwing any CEL's? I'd get those read before you do anything. After that, you can start looking into stuff. Things on a 95 are gonna start going sooner than later if you haven't replaced them already. That's why most of us use proactive maintenance instead of reactive it saves a bundle fixing a problem before it develops into something large. I'd suggest you learn to do the same.
Old Mar 9, 2009 | 11:10 AM
The Cowboy's Avatar
Nope no CEL's flashing what so ever.
Old Mar 9, 2009 | 11:19 AM
Jc61990's Avatar
check the fuse for the fuel pump. make sure it isnt blow. and you might want to check the fuel filter make sure its not clogged or something
Old Mar 9, 2009 | 11:25 AM
qUaTtRoA4's Avatar
possibly icv....
even though you do not have a cel....you still may have a code stored...
have your car scanned if you have not already...
gl!
Old Mar 9, 2009 | 11:34 AM
hiwords's Avatar
i've nvr seen a 2.4 a4, what country are you from? possible problems could be maf, ect, ICV or throttle body. try cleaning the maf and throttle body and change out the ect. check your plugs too.
Old Mar 9, 2009 | 01:02 PM
brrman's Avatar
Any diff between cold starts and warm starts? Could be the coolant temp sensor.
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
