I need help with a coolant leak
Old Jul 10, 2008 | 09:43 PM
NickerdoodleAudi's Avatar
Default I need help with a coolant leak
Somewhere by the back of the engine please help
Old Jul 10, 2008 | 11:17 PM
audiltr's Avatar
Default RE: I need help with a coolant leak
could be leaking at the enging coolent temp sensor. or the coolant hose buy the oil filter check the clamp it might be missing
Old Jul 10, 2008 | 11:22 PM
not by the oil filter
more by the back of the engine is that the coolant temp sensor
i thought it was in the lower radiator hose but is that it on the back of the engine
any experts on this?
Old Jul 10, 2008 | 11:43 PM
audiltr's Avatar
that is where the temp sensor is located in between the engine and the fire wall
Old Jul 11, 2008 | 12:15 AM
will i need a new sensor?
Does it clip inor unscrew?
If it screws in and it's leaking there, I can remove it and put nylon tape/pipe dope on the threads and put it back in, right?
Should stop the leak...is it possible or common that they leak there?
If they don't screw in, I need a new sensor and oring, correct?
Old Jul 11, 2008 | 01:33 AM
bump
Old Jul 11, 2008 | 06:58 PM
probably the heater core hose
gotta get a mirror to see in there better
need more brake cleaner too.
Old Jul 12, 2008 | 02:31 AM
Is a heater core and hoses a biathc to replace diy?
Old Jul 12, 2008 | 12:06 PM
The leak from the temp sensor was traveling down the heater core hose.
Ok, well I got to the dealership and got an o-ring and new clip for the temp sensor.
The old o-ring was mush. Put the new one in and checked for more leaks.
Thankfully it was not the heater core.
Old Jul 12, 2008 | 11:33 PM
S_R_N83's Avatar
The Coolant Temperature Sensor fails quite often and a lot of people have leaks around it. There was actually a recall for 2001 and up (i forget to what year) if you were under 100k miles. (I don't know if your car is a 2001 or not..but yea..)
Coolant Temperature Sensor..$20 for the sensor
Heater Core..a lonnnnnnng and annoyingDIY or $1000+ from the dealer. Youre lucky...
Cioffie
May 19, 2013 10:24 PM
azr3al
Dec 30, 2011 12:37 PM
supacor24
Jun 3, 2011 07:56 AM
inventorA6
Apr 15, 2009 06:46 AM
less_of_me
May 2, 2007 03:29 AM
