Idle issues...
Old Jul 1, 2010 | 04:47 PM
chocalotstarfish's Avatar
Super Moderator
Default Idle issues...
No I don't need a big brother... A little while ago I was having idle issues and found the cure was to clean the throttle body out. Last night my throttle would dive while driving almost causing me to stall the bounce around.All the bouncing is the car itself I revved it other than that it bouncing from 100-1500k is all itself! 1st Video. So today I broke down and cleaned my throttle body hence why i did the how-to and after was all said and done it was idling fine but i don't know hot to describe as hanging watch video 2 to see what I mean, I checked multiple times and I'm not throwing any codes since I cleared after the cleaning...
click to view.
Old Jul 1, 2010 | 05:23 PM
Baby Kito's Avatar
This is the problem im having only worse, when I start my car it shoots to 2000 then starts bucking and jumpin all over from 900-2000 rpms. It makes me wanna cry. Do you feel any bucking?
Old Jul 1, 2010 | 05:35 PM
Super Moderator
I did before I cleaned the Throttle Body and now is fine. just now the weird lag witch doesn't really seem to effect anything. TO do the cleaning only took me about 20 mins!
Old Jul 1, 2010 | 05:38 PM
Baby Kito's Avatar
Hmm. Well Im sure mines do to something alittle more complicated but I might as well do a cleaning hah
Old Jul 1, 2010 | 06:55 PM
kriptonik's Avatar
I saw the second video. I don't think that's normal. I guess try resetting the car (you do have radio code right?) and then take a drive for several miles and see if any code comes on. It usually takes a little while for the engine to recognize if anything is not working properly.
Old Jul 1, 2010 | 08:38 PM
A4 2000's Avatar
Are you sure its not maf sensor related?
Old Jul 2, 2010 | 09:33 AM
Super Moderator
Well I'm thinking maybe it just needed drove a little after the cleaning! Everything is smooth as an 18yr olds ***! Might just be me but seems to be a lil' more spunky and responsive!
Old Jul 2, 2010 | 09:42 PM
Super Moderator
I lied bobbing throttle came back tonight so I pulled and cleaned MAF and put in a new airfilter... hope this works...
Old Jul 3, 2010 | 03:00 PM
kriptonik's Avatar
Updates?
Old Jul 3, 2010 | 03:45 PM
Super Moderator
Well last night, I pulled the MAF and cleaned it and changed the air filter. Still the same. Anyone got any ideas? Codes I got before MAF cleaning P0137 and P1127...
