Idle Problem but not always..Ideas Pls
Hey people I am new in this forum I need help pls throw some ideas...
1999 A4 1.8T/Q 5-speed and it has 115,000
Problem: The idle(rpm) goes up and down once a week or so and it reads between 400-1300rpm sudden bouncings and it wont stop until I stop the engine and turn it back on. This happens sometimes when I am on highway or local.
What I have Done: I checked almost everything sparks, plugs, gaskets, oils, filters, air hoses, coolant hoses, valves, coils, I have done my timing maint, oil change, I even cleaned the throttle. Turbo is stock but brand new, new gas cable, new belts and My clutch is also in good condition (checked by pros)
any ideas so far... thanks pple
I cleaned the throttle body there was no change
There are no codes shown on the reader and my ICM is new too.
Plus I took my car to an inspection center even their computer couldn't find the problem.
Thank you guys for the ideas....but I still have to find the reason
try a throttle body alignment, if you have not already.
Disconnect the battery for a minute or two.
Hook it back up, and put the key in the ignition, and turn it to the on position but do not start the car.
Wait about 60 seconds or so. You'll hear the TB going through it's alignment process while you wait.
If you haven't tried that, it may help.
Good luck.
Good luck.
