Idling HELP!
Old Dec 12, 2012 | 07:27 PM
bigred'sB5's Avatar
Default Idling HELP!
Hey guys, one of my friends has a 97 1.8T with APR stage 3 with some idling issues. When idling the rpm's will bounce around, sometimes it idles too low (like 400-500), and it has stalled from this before. Also, after filling up the gas tank it will idle funny. Most concerning is the fact that she's not throwing any sort of codes, no CEL or anything. Should I still scan it with vag-com?
My first thought was checking the spark plug gap because stage 3 runs a gt28, but they're already at .026. I'm inclined to think it might be her evaporation purge valve, I've seen a video of a B5 with a bouncing tach and the poster said that replacing their EPV fixed it.
I have a 98 1.8T with a perfect EPV, should I just take mine off and test it on her car to see if that's the fix?
Any help would be greatly appreciated. Below is a link to a video of her tach while driving, clutching and letting her rpm drop to idle.
idle problems - YouTube
Old Dec 17, 2012 | 02:11 AM
bigred'sB5's Avatar
Bump.
Old Dec 17, 2012 | 02:22 AM
redline380's Avatar
Legal Moderator
dont be concerned with the evap system. you could literally take it all out and nothing will happen. id look into either a vacuum leak or throttle body first. how does her car boost?
Old Dec 17, 2012 | 12:15 PM
meloman's Avatar
^this
Do you have more info on the plugs (miles, brand)? And have the coilpacks ever been replaced?
Old Dec 18, 2012 | 12:08 PM
Dallas09's Avatar
Also might want to try a throttle body adaptation.
Old Dec 20, 2012 | 10:01 PM
badnewsbeesh's Avatar
it boosts just fine. not thinking its coil packs either. i'm using the plugs that apr recommends. about 155K on it.
Kiddo
Feb 19, 2014 05:00 PM
tnorm077
Mar 27, 2013 08:41 PM
chito31
Sep 15, 2008 03:10 PM
mrbear
May 7, 2008 09:32 PM
kextyn
Oct 16, 2005 08:06 PM
