installing lower right side molding
Old Mar 11, 2009 | 08:41 PM
audib5971's Avatar
Lightbulb installing lower right side molding
my molding on the right rear passenger side broke off a while ago so i bought a new one from audi. I cannot get this thing on n neither could the mechanic. can anyone relate n help me? thanks!
Old Mar 12, 2009 | 01:58 AM
Tweaked's Avatar
Open the door and remove the little screw in the molding, towards the front of the door. From there, just rip it off. You might need to replace some of the plastic clips under the molding as they tend to break.
Old Mar 12, 2009 | 12:17 PM
brrman's Avatar
the molding should slide forward and come off after the screw is removed. No need to "rip" it off... Be nice to your baby.
Old Mar 12, 2009 | 05:23 PM
Tweaked's Avatar
Bah. Rip it off! The dirt and grime over the years makes it difficult to usually slide off, they can be a real btch. Rip it off!
Old Mar 12, 2009 | 06:06 PM
never_enough's Avatar
with all that rust on the back side of the molding, you're more likely to shred the paint behind it if you slide. maybe not rip so much as gently wiggle it off. it really should just pretty much fall off in your hands. as for the screw, it WILL be corroded. hit it with a shot of blaster then grab your nut with some pliers and get the screw from the backside. i would suggest cleaning it up really well before reinstalling as a ton of stuff builds up in there.
Old Mar 13, 2009 | 02:08 AM
Tweaked's Avatar
Very good point. Those screws suck. If they get stuck, you can break the molding off and use some vice grips on the opposite end to try and work it out. It's a good idea to replace those screws and use some anti-seize on the threads before reassembly.
Old Mar 13, 2009 | 09:56 AM
audib5971's Avatar
thats exactly what happened with the screw. i could not get it off for **** though. i just left it their and slid the molding over it. i dont know how this will work out, but its good enough for now. thanks guys.
Old Mar 13, 2009 | 05:18 PM
Tweaked's Avatar
Rust breaker and vice grips will do the trick. Even though it's small, the screw does hold the molding from shifting off of its clips. Otherwise, you'll knock a curb with the bottom of your door and the molding will fall off. Kind of embarrassing when you're opening the door for a lady friend.
Old Mar 13, 2009 | 07:15 PM
audib5971's Avatar
haha. true trueee. the "lady friends" are the main reason every guy on this site owns an audi. ya im going to the shop soon and Im going to tell them to take that screw off once and put a new 1 in. Until then, im parking on the curb.
JVL
May 5, 2009 04:15 PM
Cruz734
Oct 31, 2008 06:02 PM
njm23
May 31, 2008 08:39 PM
Trey25
Aug 8, 2006 12:42 AM
robsilvr85
Nov 20, 2005 11:41 PM
