Installing a switch from fuse panel
Old Aug 2, 2008 | 05:15 PM
Dallas09's Avatar
Default Installing a switch from fuse panel
Alright so i want to install a switch for one of my fuse panel items. Im thinking i would remove the fuse and then run wire from there to an inline fuse to a switch.. Im trying to figure out the best way to connect the wire to the fuse slot though, any ideas?
Old Aug 3, 2008 | 08:02 AM
CycloSteve's Avatar
Member
I would opt for something non-permanent. See if you can find some spade-connectors which will fit into each side of the fuse (or modify some) and go from there. In anycase, what are you trying to "switch"?
Old Aug 3, 2008 | 05:30 PM
Dallas09's Avatar
ABS module, since im going to get flamed for this ill explain why. I completly agree with ABS on pavement and wet pavement, its a fact that it works way better not only for control but stopping distance. Anyway i want it switchable for snow and ice cause the tires wont dig, mainly for messin around or drifting or if i need to panic stop and i want to switch it. Anyway any idea where i can find some spade connectors, or should i just rip them out of a fuse or something?
muffinman
Aug 12, 2010 02:24 AM
xster
Dec 17, 2008 02:02 AM
shawten
May 5, 2008 01:45 PM
black991.8tq
Feb 24, 2007 12:08 PM
