just to confirm... there is no camber adjustment right?
Old Jun 8, 2012 | 02:39 PM
Boober's Avatar
Default just to confirm... there is no camber adjustment right?
what up everyone, i noticed that my drivers-side front is wearing the shoulder significantly more than the other side. from what i remember there is pretty much only toe adjustment... just want to confirm this. thanks
Old Jun 8, 2012 | 03:09 PM
MetalMan's Avatar
That is half-true. A normal alignment won't adjust camber. HOWEVER the subframe can be loosened and shifted to shift your camber setting. For example, if your drivers' side camber is -2 deg. and your passengers' side camber is +2 deg., you can shift the subframe so both sides will have 0 deg. of camber.
I can send you an email containing the alignment PDF if you'd like. Soon I'm hoping to find a shop local to me which will perform this type of alignment, and I think you'll have to search for shops that do frame alignment.
Old Jun 8, 2012 | 03:34 PM
Boober's Avatar
****, sounds like a lot of work... would this correct caster as well or would that be due most likely to bend control arms?
Old Jun 8, 2012 | 04:14 PM
MetalMan's Avatar
I'm not sure if the subframe can be moved forward/backward like it can side-to-side for caster correction. The PDF of alignment I'm sending you doesn't seem to mention it, or perhaps I didn't look hard enough.
Old Jun 8, 2012 | 04:53 PM
Boober's Avatar
I think you're right. I'm all but 100% certain its bent control arms from when I hit a curb last year. Had to replace the spindle cause it was bent and that corrected almost all the problem but the caster is now off... i have the control arms to replace just havent had the time and waited since it doesnt add wear on the tires.
I just looked at the alignment print out from the place I took it to after replacing the spindle and tie rod end... they set it at +.20 on the left and right, total of +.40 overall toe and its been chewing up my tires. They way shady and tried to sell me tires right now. I walked out and gonna take it to a better place I was just recommended to.
Old Jun 8, 2012 | 05:59 PM
hartsoe1's Avatar
Default camber
I talked with my guy about it, and the 4 wheel alignment is $100 and he said he would charge me another $50 to move everything else around. probably use a pry bar or axe handle to move it trial and error until he gets it right. I'm sure Audi has something to do it for $$$$$$$.
Old Jun 9, 2012 | 12:08 PM
audinoob27's Avatar
Is there a sears auto near? It's 86 dollars and they only charge you extra is you need shims
Old Nov 17, 2016 | 03:21 PM
3AudisMA's Avatar
Default Request Link to S4 B5 Alignment PDF
I'd appreciate a link to the Alignment PDF mentioned by Metalman on this thread on 6/8/2012. Thanks.
Old Nov 18, 2016 | 12:26 PM
MetalMan's Avatar
It's in the Bentley manual, which can be found online if you search carefully, or you can buy it.
jscott12345
Dec 7, 2009 10:01 PM
steckrca
Apr 21, 2009 09:46 AM
jax.b5.a4
Dec 8, 2008 06:54 PM
sline_a3
Apr 15, 2008 01:23 AM
zoti
Mar 1, 2007 03:43 AM
