Just got a 99 A4 1.8t Questions
Old Oct 15, 2009 | 08:46 PM
  #21
Novoken's Avatar
Yeah I turn it off, then turn the car off then back on, and its back on on its own. Weird.
Old Oct 15, 2009 | 09:40 PM
  #22
bradtyler02's Avatar
Yeah, that is pretty wierd... never heard of that problem before...
Old Oct 21, 2009 | 10:26 PM
  #23
Novoken's Avatar
So I checked and set it to stay at Fahrenheit, but when you turn the car off and then on it goes back to Celsius. Can it be a fuse or something?
  #24
Novoken's Avatar
Originally Posted by ghost6303
yes, there are radio removal tools. it looks like a slimjim for the radio almost. there are either 2 or 4 of them and you put them in the small openings in the corners of the radio to release the clips.
Where can you buy these?
Old Oct 22, 2009 | 01:45 PM
  #25
B5Bobby's Avatar
i just used a thin metal nail file with a point to get mine out haha it didnt damage it and it worked. put it straight in and push the little clip holding it to the right on the right side and pull it forward a little so it stays unclipped, then do it to the left side just push the clip to the left. then it should slide out.
oh and just something you should know incase you dont already. if you plan on replacing your stock stock stereo, later on down the road if you need to scan your car for codes or get it smogged you will not be able to link to your car without the stock stereo in.
i ran into the same problem. so whenever i scan my car i just plug in my stock stereo real quick and it works even with it on safe mode.
Old Oct 22, 2009 | 04:35 PM
  #26
dragonrage's Avatar
I can scan my car with VAG-COM with a piece of crap aftermarket HU in there.
Old Oct 22, 2009 | 08:16 PM
  #27
screamin demons's Avatar
I'd let audi try and fix the stock radio because it's uniform and looks nice in the car. Also call the guy u bought it from and ask him to give you any code he knows of. When i bought mine from the original owner my radio card had been scratched out and a sticky note with the new code was on the manual. The owner said Audi did it so maybe pull the radio out and give them some info off the back see if they give you a diff code.
Also i'm having to replace the thermostat in mine because it won't get hot. My temp gauge stays next to the C but used to go to the middle and sit no matter how hot or cold it was. Now the thermostat is stuck open so water is always going out to the radiator to be cooled. Even when the engine is cold
-Tyler
Old Oct 22, 2009 | 08:47 PM
  #28
Novoken's Avatar
Hmm thanks for the info, Im going to take it to the mechanic next week Im trying to buy a A4 avant and take both cars to get checked. Im going to leave the stock radio in, just need get the serial number, because the code I got from the card does not match. Ill try contacting the PO, but doubt he will be any help. Said he was a Audi fanatic, had 7 audis. And never came across any of the issues this car has..... Sure!!
Old Oct 23, 2009 | 01:32 PM
  #29
Novoken's Avatar
So after 1 hour i was able to rig it open, yay and code was on the top of the radio. Wify got tunes now lol I used a bunch of files and metal parts to get it out. And the code was right on top of the radio.
mblayton
Jan 7, 2010 07:35 PM
playboy00786
May 31, 2008 06:37 PM
zchb9
May 20, 2006 01:29 PM
portwolf
May 18, 2006 03:27 PM
VolcanicBlackA4
May 18, 2006 02:11 PM
