Just seafoamed car, then got a CEL
Old Aug 23, 2008 | 01:36 PM
Jc61990's Avatar
Default Just seafoamed car, then got a CEL
ok, so i read the tutorial on how to seafoam, and i did it correctly, so i took my car for a drive afterwards, and got a CEL, took out my handy dandy usb vagcom and scanned it came up with this
VAG-COM Version: Release 409.1-US
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 8D0 907 559 C
Component: 1.8L R4/5VT MOTR AT D03
Coding: 06251
Shop #: WSC 06335
7 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-10 - Please Register/Activate - Intermittent
16687 - Shareware Version. To Decode all DTCs
P0303 - 35-10 - Please Register/Activate - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 35-10 - - - Intermittent
16685 - Shareware Version. To Decode all DTCs
P0301 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans
Controller: 8D0 927 156 BN
Component: AG5 01V 1.8l5VT USA 8508
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
No fault code found.
Old Aug 23, 2008 | 01:53 PM
onepoint8tee's Avatar
When your engine sucks up some seafoam, the plugs get a little soaked while also restricting 02 to the combustion process and so you misfired. You should change your plugs after seafoaming anyways.
Old Aug 23, 2008 | 02:11 PM
Jc61990's Avatar
ok, I'm in autozone now getting plugs, I came here to get my car scanned, their scanner came up cylinder 1 3 4 misfired that's it
Old Aug 23, 2008 | 02:24 PM
Jc61990's Avatar
ok back home, i posted previous message from my iphone while i was at autozone, i was showing the guy the codes i got compared to the codes their scanner got. they got
P0301
Misfire on Cylinder 1
P0303
Misfire on Cylinder 3
P0304
Misfire on Cylinder 4
Possible Causes
1: Ignition system fault-spark plug(s). ignition wires, coil
2: Vacuum leak (im going to clamp my hoses after posting this)
3: Injector Fault
4: High or low fuel pressure
ok and also how do i clear my CEL they told me they couldn't clear it for me.
Old Aug 23, 2008 | 02:50 PM
Jc61990's Avatar
ok... the plugs the guy at autozone sold me need to be gapped, whats the right gap and how do i set the gap, i have one of them tools to check gaps but i never set a gap before
Old Aug 23, 2008 | 04:05 PM
Jc61990's Avatar
ok awesome, just finished replacing plugs, bought a new gapper tool and set gaps to .030, after i put the last coilpack on i started my car and woot! no CEL. looks like that fixed it, and man my old plugs were oily
Old Aug 23, 2008 | 04:55 PM
sineo's Avatar
Then you probably ought to replace your well gaskets and VC gasket.
Old Aug 23, 2008 | 04:58 PM
Way to go. Hopefuly your plugs do not actually have engine oil on them, but just soaked with seafoam/soot/carbon from the cleaning. If you had engine oil on top of the plugs your valve cover gasket needs replaced. If there was engine oil on the bottom/spark part of your plugs then you need new piston rings. Now I'm just making your paranoid
Old Aug 23, 2008 | 05:01 PM
Jc61990's Avatar
right.... *looks in wallet*.... will 2$ be enough?
Old Aug 23, 2008 | 05:04 PM
Well it's pretty likely that all B5's by this point would need a new VC gasket anyways. My 00 was leaking at 75k miles, and the one on my 97 w/170k I don't think was ever replaced
