K03s Overboosting
i replaced my stock K03 in my 98 1.8tq with a K03s and am having an overboost issue. After some research I have found out that the actuators on our B5s open with less pressure than on the B6's. This explains the overboost issue.
Can I loosen the wastegate actuator enough to compensate? Or do i need to throw on the old actuator?
So I tested the wastegate actuator pressure today. It actuates around 11psi, so I'm guessing that even if I would have loosened the wastegate it wouldn't have solved my problem...
Here's what I don't get, If I disconnect my N 75 it still overboosts and kicks into limp mode.
I thought the way to see if the N75 was bad was by unplugging it. This should actuate the wastegate by pressure off the compressor right? If i'm right, the wastegate would then open at 11psi (according to my pressure test on the actuator) Is that too much pressure on a 98t q?
