Leaking coolant from this..thing? What is it? (Pic Inside)
I'm leaking coolant. Sometimes not a lot, sometimes quite a bit. Found the source (I think?).. So the hard pipe that connects to the bolt? It's leaking from right under there.. what is that piece? Maybe it's an o-ring?
https://drive.google.com/file/d/0By1...it?usp=sharing
Have you replaced the coolant flange? If not it's probably time, even if it's just the oring between it and the metal pipe it's always a good idea to do the flange if you're digging into it already. Temp sensor wouldn't be a bad idea either depending on how it looks, make sure to only use OEM parts, don't even think of going aftermarket for this.
crazy, i replaced mine last year when i rebuilt the head and that flange blew up last night.... check out the thread i just posted about it.
https://www.audiforums.com/forum/b5-...cluded-207730/
Are you kidding? I did the timing belt, control arms, drive shafts, and numerous other things to my B5 when I had it... the coolant flange is by far the biggest pain in the *** I ever encountered on that car! Hahaha... I laugh to keep from crying
i just took out the one 10mm bolt holding the metal coolant line to the intake manifold to give it some wiggle room and the rest was pretty easy. message or email me if you have some questions: joshuadannais@gmail.com
votblindub
Sep 9, 2007 08:46 PM
Bryceaudi
Jul 31, 2007 03:42 AM
