LED install disater
Old Jul 20, 2010 | 09:37 PM
MiamiA4guy's Avatar
Question LED install disater
I went to install a new LED on my side marker's today and i get home from buying the LED's and i go to put them in and they dont fit which is what ever ill go buy some more later but as i go to put everything back to the way it was i notice that my turn signal's and my hazard button's are not working at all my turn arrow's arent even working on my dash and my hazard signal button each time i press it it dim's but does not do anything I am completely stumped on this any suggestion's guy's?
Old Jul 20, 2010 | 09:47 PM
onepoint8tee's Avatar
I'd normaly say your flasher relay (the hazard switch IS the relay) is bad - it controls turn signals, etc. But I don't know how you could have messed it up by messing with your side marker lens/bulbs unless you shorted it. I don't know what else to say other than to suspect your flasher realy is bad.
Old Jul 20, 2010 | 10:00 PM
MiamiA4guy's Avatar
Ya but i dont kno bro that's the stupidest thing and i could not of had shorted out that realy the LED never got put in to the socket and the car was not even on???
Old Jul 20, 2010 | 10:06 PM
Don't know what else to tell you other than it could be a freak coincidence and that the flasher relay is sort of a common failure part.
Old Jul 20, 2010 | 10:10 PM
MiamiA4guy's Avatar
ya for real lol well i have to use my hand signal's now untill i can order one from somewhere.....I think if you put your hand up it mean's your going right and if you put it horizontal your going left correct?
Old Jul 20, 2010 | 10:15 PM
Correct, you totaly law obiding citizen..
Old Jul 20, 2010 | 10:25 PM
MiamiA4guy's Avatar
Well i made the LED's fit i cut them out on the bottom and and put them sung it the marker's so when i get my new one i can just put it on and everthing will be fine and dandy
Old Jul 20, 2010 | 10:53 PM
chocalotstarfish's Avatar
Super Moderator
stupid question but did you check your fuses?
Old Jul 20, 2010 | 10:59 PM
MiamiA4guy's Avatar
No sir i did not well this is a stupid question right back to you but where would i find the fuse lol
Old Jul 20, 2010 | 11:08 PM
MiamiA4guy's Avatar
never mind i got it
