led plate light
Old Oct 4, 2013 | 05:55 AM
gillahoon's Avatar
Default led plate light
Just put leds in my plate light old ones toast but dash is still showing light out,I know it's a led any idea how to get it out.
Old Oct 7, 2013 | 05:07 PM
jeckel20003's Avatar
If you put a resistor in series with the LED.
Old Oct 8, 2013 | 09:22 PM
kriptonik's Avatar
Do you have a B5? The B5 doesn't show any error messages for plate lights.
If its a B5, it could be other lights.
Old Oct 9, 2013 | 06:17 AM
gillahoon's Avatar
Its a 98 so really dint kn much just got car. Got led brake lights too. What kind of resistor and how do I add it. I did little rewiring to brake lights now when i step on brakes the fog light switch or the other light switch on dash lights up yellow triangle
Old Oct 9, 2013 | 09:52 PM
Clayson's Avatar
Don't do any rewiring! It may throw EVERYTHING off. What did you do? I Just posted on your other thread, but I'll say it again. 25W 100 ohm resistors. I got 'em from KrautoLED, but I'm sure eBay will have them. Super easy to install.
Old Oct 10, 2013 | 05:17 AM
gillahoon's Avatar
What I had to do is it has aftermarket tail lights are led in upper light and reg bulb at bottom of light. Bottom bulb was not working so had to tap into power line to get to come on when lights turned on. What also I found odd there is a wire that runs from pass to drivers side light to give it power. that is not factory. If I dis connect that brake light still works just no running lights
Old Oct 10, 2013 | 08:13 AM
Clayson's Avatar
Oh, never mind. I couldn't give my 2 cents about aftermarkets. Yeah, you got some crazy wiring. Sorry I couldn't help.
Old Oct 10, 2013 | 09:08 AM
gillahoon's Avatar
Gonna try the resistor is it just one or need do both tail light sides
Old Oct 10, 2013 | 09:23 AM
Clayson's Avatar
No, you need basically one per bulb. Because basically each bulb draws a certain amount of power. Halogens more, LEDs less. So for every LED you have, you basically need a resistor for it so that the computer will think its a halogen.
Old Oct 10, 2013 | 12:21 PM
gillahoon's Avatar
Txs for help. Question 2 light switches above radio. What they supposed to turn on. Fig one is fog lights mine are missing. But 2 switches I turn my headlights with lever on collom
