left front side**** clicking noise
Old Apr 9, 2010 | 07:32 PM
vlado182000's Avatar
Default left front side**** clicking noise
when i drove home today i noticed some clicking. when i got home i grabed the tire @ 12 o'clock position and pushed forward and back repetetly it has some play ...does this sound like wheel baring or something else? i checked the upper and lower control arms are pretty tight
any help would be appriciated
Old Apr 9, 2010 | 09:41 PM
chocalotstarfish's Avatar
Super Moderator
while turning or going straight?
Old Apr 10, 2010 | 12:56 AM
MrNotSoTechnical's Avatar
Not to threadjack, but what does it mean if it clicks while it's turning? I've had the problem and just decided to deal with it until I get it up to Maryland in the summer.
Old Apr 10, 2010 | 02:32 AM
Mr. Phil's Avatar
cv joint is bad... mine is doing the same thing... it sucks haha... but ill eventually fix it
Old Apr 10, 2010 | 11:05 AM
its clicking when i go straight when i hit the bumps and if i turn little to left then right it does it every time.
Old Apr 10, 2010 | 01:08 PM
kayakman13's Avatar
I get a weird clicking noise as well. Sounds kinda like its behind the pedals. Only happens when I go 40 mph+ and it sounds similar to a light switch being clicked on and off. Its random, not at a set beat. I was inclined to think it was something blowing around under the car, maybe a heat shield pushing around. Could this be wheel bearing or suspension related? Good ways to check?
Old Apr 10, 2010 | 01:23 PM
Midniteoyl's Avatar
op... wheel bearing, but check your hub/axle nut
Old Apr 10, 2010 | 04:11 PM
Mr. Phil's Avatar
wheel bearing is more of a whom whom whom noise not a click noise
Old Apr 10, 2010 | 04:14 PM
Midniteoyl's Avatar
Not really... especially when you can move the tire...
Old Apr 10, 2010 | 04:25 PM
redB5's Avatar
Most likely both are bad.. if you've been driving on a bad wheel bearing it could have eventually taken the cv joint out with it.
