limp mode? boost/sensor issue...
Old Jul 9, 2009 | 10:00 PM
jjcrt2's Avatar
Default limp mode? boost/sensor issue...
ok so aparently my o1 audi a4 1.8t is running in limp mode and is peged at 5psi of boost... i have a full borla exhaust with a cat delete pipe. ive had the exhaust on for about 5 months with no issue. i have a kn air filter and a boost gague in as well. one day i was driving and my car wouldnt get above 5psi i thought it would be a vacume leak so i checked and found nothing. then i took the negitive off the battery and reset the computer and my car was acting normal untill about 50-100 mile down the road it gos back into limp mode. if you have ne idea what i can check to figure this out or any ideas whatsoever please let me know. also if you know how to check if the maf sensor is bad with a multimeter or the o2 sensors with a multimeter could u let me know so i can check them. any suggestions will be taken to heart thanks!
Old Jul 14, 2009 | 10:02 PM
Vermont A4's Avatar
It is your MAF.
Old Jul 14, 2009 | 11:38 PM
SVT_BRYAN's Avatar
Why are you so certain it's his MAF sensor? Is there a way to check if the MAF sensor is working properly without just replacing it? I've been trying to get my car out of limp mode for almost a year now.
Old Jul 15, 2009 | 09:54 AM
jjcrt2's Avatar
yea if neone knows how to check the maf sensor let me know... like what ohms for what pin and what not
Old Jul 15, 2009 | 10:01 AM
CCA4's Avatar
Unplug it.
If the car runs better w/ the MAF unplugged then thats the problem. If it still runs like **** or runs worse than before, its somethin else. Any CELs? Codes? Keep in mind that you CAN throw codes w/o a CEL
Old Jul 15, 2009 | 10:22 AM
ghost6303's Avatar
if you are going into limp mode there should be a code stored. a dying MAF would not put you into limp mode, and it sometimes doesnt store a code unless the MAF readings are way out of spec.
Old Jul 15, 2009 | 10:33 AM
AutoUnionFan's Avatar
Sounds like a fuel trim issue that could be caused by a bad MAF, as mentioned, or it could be a leak passed the MAF that is messing things up. A leak will allow air to enter passed the MAF and the MAF readings will be low but still accurate.
I wouldnt automatically assume its the MAF. I replaced it on my old car before I found a hole in a hose. '
Do a leak test.
Old Jul 15, 2009 | 01:48 PM
screamin demons's Avatar
Mine recently started as well and my MIL light came on. I took my OBDscanner to it and i got two codes.
1 - MAF sensor output too low
2 - Boost sensor one faulty.
any idea why these two codes would pop up and make my car stumble and spit and sputter?
Old Jul 15, 2009 | 05:05 PM
ghost6303's Avatar
post the actual codes, not what your scanners definition of the codes are.
if the MAF is faulty it would cause those problems. i dont know if they meant MAP sensor instead of boost sensor...
10kRedline
Sep 3, 2017 03:18 PM
hotswaps
Aug 8, 2013 05:50 PM
hotswaps
May 27, 2013 07:02 PM
quattroforte
Feb 5, 2009 08:29 AM
djjay
Apr 20, 2007 02:17 PM
