Looking to purchase an A4 - which is better? 1.8T or 2.8?
Old Nov 17, 2010 | 05:08 PM
  #21
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Originally Posted by Tim_
Well I would assume a car that weighs over 3,000 lbs and only makes 150 HP, that would be true. That's why if I went the 1.8T route, I would only be interested in the '01 for the extra 20HP.
All it takes is a chip on the 1.8T to brighten your day.
I think its rather foolish to limit yourself to facelift models for an extra 20 crank horsepower, not even wheel horsepower.
If you really don't ever want to do any mods to the engine, then get the 2.8 and be done.
Old Nov 17, 2010 | 05:32 PM
  #22
jdahlen24's Avatar
Originally Posted by theflash
You absolutely need to find a car where the maintenance has been kept up. I swear, the majority of things go wrong at around the 70-100k mark. Here's what I've replaced so far in 3 years:
Timing belt/waterpump/thermo stat/idlers/tensioners etc (the complete job)
Valve cover gaskets, and then plugs because the oil leaked on to them
Cam seals
PVC Hoses/spider
Oil cooler
Cam chain tensioner seals
Passenger camchain tensioner (real expensive)
Coolant temp sensor
Pads and discs all around
The above was what I absolutely had to replace, and just what I remember, lol. Things I recently discovered I need to replace are:
Rear wheel bearings
Whole front control arm setup
Shocks and springs (shocks are nearly dead on non-sport)
That list is very similar(eerily similar, in fact) to what I've had replaced on my 2.8.
But while I bemoan the fact that the old girl is 11 years old now, most/all of the people who find out she's that old can't believe it. So, that's something, I guess.
When I was shopping for a car in 2003, I settled on the 2.8 because I liked the way the engine and tiptronic worked smoothly together. Plus, for the first time in my life I wanted an automatic. The 1.8 did not feel nearly as smooth.
But, diff'rent strokes for diff'rent folks....
Old Nov 17, 2010 | 08:02 PM
  #23
Tim_'s Avatar
I was talking to a friend of mine this weekend who has an S4, and he named pretty much those exact same things as well... suspension - tie rod ends, bushings, wheel bearings, and coil packs.
Old Nov 17, 2010 | 08:27 PM
  #24
Andrew149's Avatar
Also what i have found is that most high milliage a4's with the 5 speed is 2nd gear wants to pop out you can acutaly push it out with out the clutch being pushed in so watch out for bad transmissions also look for saggy headliners pay close attention to the heater/ac there known not to work to well and Cruise control and see if the cruise control works
Old Nov 17, 2010 | 09:21 PM
  #25
You never shift without using the clutch?
Old Nov 17, 2010 | 09:57 PM
  #26
NickBroderick's Avatar
He doesn't have an audi anymore. >
By the way, saggy headliner? I've never ever seen them sag, I don't really know how they could.
Old Nov 17, 2010 | 10:29 PM
  #27
Doesn't have to be an Audi to shift without the clutch.
I would ask if you shift without the clutch...but...
Old Nov 17, 2010 | 10:40 PM
  #28
I shift via magic.
Old Nov 17, 2010 | 10:59 PM
  #29
Andrew149's Avatar
Guys come on im saying the 2nd gear pops out without the clutch being engaged its a sympton on some audi's to have bad 5 speed's
and btw over here in nc saggy headliners are common
Old Nov 17, 2010 | 11:10 PM
  #30
But you do know you can shift without the clutch yeah?
If you're saying that some manuals won't stay in 2nd and will pop out, thats another thing.
