loose ball joint diagnosis help
Old May 22, 2008 | 12:42 AM
fritz's Avatar
Default loose ball joint diagnosis help
97 tqm
im working on taking out the right front spindle (wheel bearing replacment) and had trouble releasing the front lower control arm from the spindle. mistakenly used a tie rod separator and in turn damaged the rubber boot full of grease. its torn but not where it starts to bulge out. i still have the ring and was able to slap it back on but its semi loose, ill tighten it later.
my question is, will this pose a problem for me down the road, i know it will but will it be a siginificant one? i tried moving the other ball joints and they seem to be rather firm, this guy however is rather loose and easy to move around.
what say yous?
Old May 22, 2008 | 01:04 AM
fritz's Avatar
Default RE: loose ball joint diagnosis help
yeah, i think im f--ked. now i gotta drop 100 bucks on a control arm and lose about 2 days. damn it!
im suckt because im in the situation where its might as well fix it now since its open.
damn!
AudiTurbo
Mar 21, 2012 01:47 PM
ShqeviTT00
Sep 15, 2010 12:41 PM
blazinhaze609
Mar 5, 2009 01:50 PM
mattr7786
Aug 18, 2007 05:14 PM
morrisonjd84
Dec 14, 2004 01:43 AM
