Lots of oil on spark plugs
So I decided to change my spark plugs today and I had a nasty surprise. There was a considerable amount of oil and sludge on the plugs/in the spark plug hole. I also noticed that the gap was enormous, the biggest size I can measure is 0.040 and they were bigger than that!
What is causing oil to leak into this area? Head gasket? I should mention that I changed the valve cover gasket last summer so I don't think the leak is from there.
Here is a picture:
Thanks
Here is a picture:
Thanks
I just realized what happened here. In the fall I had a leaking valve cover gasket and I changed it out. I have not changed the spark plugs since then so the oil I found today is just residue from before I changed the valve cover gasket.
I'm going to clean out the area and the new plugs and run it for a few days. Then I'll take a look to see if it is indeed leaking or what was in there was just residue from the old valve cover gasket.
Question about the huge gap though, what kind of effects would a large spark plug gap have on performance?
if you are running stock coils, the largest gap youll want to run is .030 inches, but most people settle on .028 inches. some others, like myself, upgrade to fsi coils. we run gaps of about .040 inches
Me Too
I have oil on plug #3, quite a lot. A little bit on other plugs. This post is encouraging, if I can solve the problem with a valve cover gasket. I was fearing head gasket leak but I have no other symptoms.
Cautious optimism!
May I ask what "the gasket in the middle" means? I have a 4 cyl 1.8t.
Cautious optimism!
Cautious optimism!
But first, I need to clean my PCV system thoroughly. The spark plug oil leak and one other oil leak started when I replaced the "T" PCV system hose at the back of the engine which had a big tear in it. Now, with the PCV system tight, I suspect blow by as the cause of the oil leaks.
John
