MAF replacement and...
Old Aug 15, 2012 | 05:32 PM
supergoober752's Avatar
Default MAF replacement and...
Hey guys, been searching around some threads and havnt found an exact answer. I did the MAF test on my audi 01 a4 1.8t and found my MAF was completely gone. i unplugged it and the car ran amazingly better. I bought a new replacement MAF and put it in yesterday and it would idle really bad and i lost a lot of power when i plugged it in.
Do i need to cycle through it for my ecu to adjust back to normal? i havnt cleared the CEL yet with my vag com, also the new maf came with a note saying sometimes the "adaptations" need to be reset and cant be done with an obi II. i have the APR chip, should i call the place and ask?
Thanks!
Old Aug 15, 2012 | 05:50 PM
CCA4's Avatar
Assuming you bought an AWM MAF, you need to clear the code for starters. Then I would probably do a throttle body alignment with Vag Com and see how it feels. For the most part, a new MAF should be one of those "plug-and-play" type items...
Old Aug 16, 2012 | 05:04 AM
plugged it back in, cleared the CEL and tried to do the throttle boddy adjustment but i have the cable off ebay not the full ross tech one so i guess i couldnt do it. ill try to hack it tommorrow.
Once i plugged it in, it ran SO bad, idle was crazy, hit the gas and pretty much 40% less power then when its unplugged. tried to do the drive by wire where you turn the ignition on for 3 min, didnt work.
Any suggestions?
Old Aug 16, 2012 | 08:38 AM
CCA4's Avatar
Where'd you get the MAF from? It's not often you get a bad part but I've seen it happen.
Old Aug 16, 2012 | 03:25 PM
you may hate me for this one but on a lot of the forums this got good reviews and no one had a problem
01 - 06 AUDI A4 TT VW GOLF JETTA 1.8T MAF AIR FLOW SENSOR 0280218063 06A906461L | eBay
im thinking i may just TRY to clean my old one and see if by the grace of god it works again
Old Aug 16, 2012 | 03:42 PM
TheFrostyArab's Avatar
Default That price
is a little low for a brand new OEM/AudiVW MAF sensor.
Old Aug 16, 2012 | 04:48 PM
CCA4's Avatar
lol no hate, but that reinforces what I thought originally about a bad part
Old Aug 17, 2012 | 06:06 AM
do you think its worth bringing to the shop to pay for a throttle body adjustment?
Old Aug 17, 2012 | 08:46 AM
CCA4's Avatar
absolutely not. You're DBC right? If you used the key on method, the TB is just fine. I would spend that money on a new MAF. Where are you located? I would even let you borrow mine just to rule it out.
Old Aug 17, 2012 | 03:48 PM
Seattle, Wa area.
ill try cleaning my old one and if all else fails buy a new one.......depressing
